How use BME688 BSEC static library in ESP32?
I am Mohammad, and recently, I have worked on a custom ESP32S3 board.
On this board, there is a BME688 sensor to measure temperature, humidity, pressure, and gas data of an environment.
I want to run "bsec_iot_example" project to get "IAQ" values and investigate the air quality of an environment.
As I use an ESP32S3 board, I should do the following steps:
Step 1: Make a new project in Espressif-IDE
Step 2: Add "BME68x senor API" files to the project
Step 3: Add "BSEC static library" files to the project
Step 4: Change or edit "CMakeLists" files
Step 5: Compile or build a project
My problem is:
How can I add "BME68x senor API" and "BSEC static library" to the project and how can I change or edit the "CMakeLists" files? I am so confused.
What is the solution?
Can you provide me a step by step guidance/approach to add these files to the project and compile it successfully?
Thank you in advance.
Best regards,
Mohammad
