We are developing a device what would use pressure sensors such as BMP388, BMP380, or BMP280.
The pressure sensors will be securely mounted in a plastic enclosure. The enclosure will be mounted to a surface using strongh magnets. Consequently, the pressure sensors will be 1cm from a magnetic field that may be as strong as 20,000 Gauss.
Have these pressure sensors been tested for that kind of magnetic environment? If not, is there a straightforward developer kit we can use to help us to decide if there will be an issue?
