I have two BMI323 sensors. I used the official API example for gyro self-calibration from BMI3XY SensorAPI - self_calibration example to calibrate them.
Before calibration, I ensured that the gyroscope was placed horizontally and kept completely still. However, the calibration results seem unusual, and I am not sure where the problem is. I am wondering if this could be caused by chip damage due to soldering or if the results are actually normal.
I am using an ESP32-S3, reading data via I²C. I also ran the selftest example from the same API, and all tests passed, so the sensors appear to be working normally.
My main concerns are:
The gain values seem significantly smaller than expected.
The offset values frequently show numbers like 1023. Is this a valid reading, or does it indicate a fault?
Below are the multiple self-calibration results I obtained for each sensor:
Sensor 1
Self-calibration for sensitivity mode
Self calibration is successfully completed
Result of gyro dp offset x(LSB) is 0
Result of gyro dp offset y(LSB) is 0
Result of gyro dp offset z(LSB) is 0
Result of gyro dp gain x(LSB) is 124
Result of gyro dp gain y(LSB) is 124
Result of gyro dp gain z(LSB) is 7
Self-calibration for offset mode
Result of gyro dp offset y(LSB) is 4
Result of gyro dp offset z(LSB) is 1021
Result of gyro dp gain x(LSB) is 0
Result of gyro dp gain y(LSB) is 0
Result of gyro dp gain z(LSB) is 0
Self-calibration for sensitivity and offset mode
Result of gyro dp gain x(LSB) is 123
Sensor 2
Result of gyro dp gain x(LSB) is 122
Result of gyro dp gain y(LSB) is 2
Result of gyro dp gain z(LSB) is 6
Result of gyro dp offset z(LSB) is 1023
Could you please let me know if these calibration results are within the normal range, or if they may indicate hardware damage?
Thank you in advance for your help.
