Status codes for the BME688 sensor data
Hello Community,
I am working on the BME688 sensor with the Raspberry pi.
I am referring to the BME68X Sensor API  to port the application to raspberry pi CM4.
I am not using the COINES Tool to communicate with the sensor device. Instead of that, I am using the I2C interface.
Till now I am able to port the application & run the Force mode example successfully.
& getting the following result as output.
Note: I haven't printed the TimeStamp value here.
I2C Interface
Sample, TimeStamp(ms), Temperature(deg C), Pressure(Pa), Humidity(%), Gas resistance(ohm), Status
1, 00000000, 31.53, 94684.11, 44.89, 219459.92, 0xa0
2, 00000000, 31.71, 94687.38, 44.91, 7887.60, 0xb0
3, 00000000, 32.17, 94678.07, 44.96, 9411.76, 0xb0
4, 00000000, 32.58, 94677.10, 44.99, 12741.39, 0xb0
5, 00000000, 32.85, 94684.97, 45.00, 16060.23, 0xb0
6, 00000000, 33.04, 94675.18, 44.99, 19282.92, 0xb0
7, 00000000, 33.17, 94677.45, 44.97, 22260.87, 0xb0
8, 00000000, 33.29, 94680.03, 44.93, 25559.11, 0xb0
9, 00000000, 33.37, 94682.83, 44.87, 28064.02, 0xb0
Now,
I would like to know,
1. Is this data is valid or not?
2. What does status code 0xa0 & 0xb0 actually mean?
Will you please help me to understand this?
Regards,
Shiv Patil.
