yesterday I talked to a guy from Bosch Sensortec on their booth at Embedded World and told him it would be nice if devices like the BME280 had unique IDs similar to the 1wire devices. He said that he thinks they have that, but it might only be documented in the BME680's datasheet. So I checked that, but only found the "Unique Chip ID" that's also present in the BME280 documentation. That ID is only unique per sensor model, but I was looking for IDs that are unique to each single device.
So, either it was a misunderstanding and he was referring to that model ID, or there is a per device unique ID that's not documented in either of the manuals.
I noticed that there are some apparently random bytes in undocumented or reserved areas of the BME280's register file, so I still wonder if some of them form a unique ID.
As a workaround I currently construct a unique ID by hashing the calibration data, but of course I can't be sure if there are no two devices with the identical calibration data, so it would be nice to have an ID that is guaranteed to be unique.
cu
rmax
