Values for the safety calculation according to DIN EN ISO 13849-1 from BMP384
Hello
The BMP384 pressure sensor is installed on a printed circuit board.
As the circuit with the BMP384 pressure sensor is safety-relevant, I need to determine data for the safety calculation (in accordance with DIN EN ISO 13849-1).
To do this, I need at least one of the following standard values from you:
- MTTFD (mean time to dangerous failure) [years]
- Lamda D (dangerous failure rate of a component) [1/hour]
- MTTF (mean time to failure) [years]
- MTBF (mean time between failures) [years]
We also need these values:
- T10d (mean time until 10% of the components fail dangerously) [years]
- TM (service life) [years]
Unfortunately, I cannot find any of these values in the data sheet.
These values relate exclusively to the values you have determined.
Greetings
N.Niemeyer
