What are Python code steps to enable Interrupt BMI160
What are the Python code steps to enable INT1 and 2 to be external level detecting Inputs?
53 = x"00" disables Int as output and makes Int2 and Int1 Input Level Detectors
54 = x"30" enables both Int 2 and Int1 as nonlatched Interrupts
Anything else required?
Best reply by shellywang
Take the INT1 pin as an input for example, below are the steps:
  • Disable the INT1 output (by clearing Bit 3 in Register 0x53, which then will be 0).
  • Set INT1 as an input, and select Level or Edge Sensitive (by writing 0x10 to Register 0x54).
  • Connect the external input signal (Vsync) to the INT1 pin.  Suppose that Vsync is an active high signal.
  • In the FIFO, enable accel data, and enable FIFO header and FIFO TAG1 (0x58 in Register 0x47)
In normal stage, Vsync is low and the FIFO frame header is 0x84 (fh_ext<1:0> = 00). Once Vsync is issued, the related FIFO frame header will be 0x85 (fh_ext<1:0> = 01).
