What is IAQ? Understanding & Calibrating BME688 Static IAQ Values
I am currently working with the BME688 VOC sensor and I’m trying to understand the meaning and practical use of the IAQ and static IAQ values. I know that the IAQ index is a relative metric, so for calibration purposes I am focusing on the static VOC (static IAQ) value instead.
However, the static IAQ output does not appear to have defined units, and I want to ensure that the calibration approach I use leads to reproducible and comparable results across different devices and environments.
I would really appreciate clarification or recommendations on the following:
  • What exactly is the static IAQ value measuring, and how should it be interpreted?
  • Are there recommended methods for calibrating or normalizing the static IAQ output?
  • Are there limitations or considerations when using static IAQ for reproducible measurements?
  • Any documentation, examples, or best practices related to interpreting or calibrating IAQ/static IAQ?
Thank you very much for your help!
Sensor
BME688
Application
Airquality
Label
Sensor API
BME688
