Where is the example that works for getting the magnetometer data?
I am working on BMX160 using I2C, I can get the data of Accel  but can't get any valid Magnetometer data. I found that almost all the examples using bmm150 to get this data. https://github.com/BoschSensortec/BMI160_driver/wiki/How-to-use-an-auxiliary-sensor-or-magnetometer-with-the-BMI160. and /mems-sensors-forum-jrmujtaw/post/bmx160-magnetometer-problem-BNstnEWxUtHtAq0 , but I found some defines in bmm150_def.h are not the same as the datasheet of BMX160. For example :
#define BMM150_REG_CHIP_ID                        UINT8_C(0x40)
it should be 0x00
#define BMM150_CHIP_ID                            UINT8_C(0x32)
it should be 0xD8
I am worrying about it doesn't work.
Best reply by Minhwan
Please check my zip file.
You can check the bmx160_read_sensor_data example and modified bmi160 code.
Thanks,
bmi160.zip
76.49KB
