    0261230263, 0261230185
    romy
    where can i obtain the characteristic data (voltage-pressure) for these two map sensors?
    regards
    Hi romy,
    We didn't understand your question. Can you provide a detailed description?
    well, i dont know what else to say.
    the input-output relationship. the output voltage as a function of pressure, or a table or at least a graph at a specified input voltage. how many volts come out if i change the pressure the sensor is reading. a datasheet would be great.
    if i knew what is inside (e.g. a member of the mpx-family?) i could perhaps find this info my self somewhere.
    kind regards
    Hi romy,
    Which sensor you used?
    If you used Bosch sensor, usually electrical parameters are already described in the data sheet. If internal information is involved, it will usually not be disclosed.
