09-16-2020 06:10 PM
Dear all,
for our development project (a mobile device with a camera system) we are planning to use the BNO055 (9-axis) IMU because of the sensor fusion. We are also discussing to use the BMI085 IMU (6-axis, no sensor fusion). Is the accuracy of the IMU with the 9-axis better than the 6-axis IMU? Is the accuracy difference recognizable?
Are there other important issues for choosing the BNO055 or the BMI085? I also in the datasheet that the BMI085 has less operating power supply.
The bandwidth of the BNO055 has 1000 Hz and the BMI085 from 6 to 684 Hz. Is that recognisable in the practical use (our typical use is holding a smartphone an taking a picture and so there are no fast movements of the device with the IMU)?
Thank you!
Thank you for your help!
09-17-2020 10:59 AM
Using which sensor are mostly depends on your demands.
BNO055 have accel/gyro/magnetic sensor, could output absolute orientation with Fusion software. If you need direct Euler angle or Quaternion vector, BNO055 is suitable.
BMI088 have accel/gyro, could sync accel/gyro data.
Regarding bandwidth, do you mean gyro bandwidth?
