05-30-2024 09:35 AM
Hi Bosch community,
I have purchased BME688 sensor and have updated the version of BME AI Studio to the 2024 version for windows.
Recently, I was testing the BME688 sensor in an application where it detect flavors and fragrances in a relatively confined space. I evacuate the gas by means of a vacuum pump, which brings the pressure up to 500 pa,the sensor is de-powered.When analyzing the data, I found that the length of resistance data recorded by different sensors was not consistent.
Thank you in advance for your help.
06-04-2024 03:19 PM
Hi MrFish,
Is it a vacuum environment in the space after removing gas through a vacuum pump?
At which time did you record sensor data?
a month ago
Hi ,
Thanks for your response .
The vacuum pump makes the pressure not less than 300pa,the test is documented once the pressure within the testing area equalizes with the ambient atmospheric pressure.
