    BHI160 sends no data
    Highlighted
    Re: BHI160 sends no data
    Again this enforces my initial hypothesis of an init failure. It may sound stupid, but did you forget the pull-up resistors on the auxiliary interface ? BHI160 uses I2C for internal communication, but lacks the built-in pull-ups. External pull-up resistors are mandatory.
    If you connect your oscilloscope to the secondary i2c bus, are you able to log the bus activity and post it here ?
    Highlighted
    It indeed appears that the resistors on the auxiliary interface are missing. I will check with my colleague how this can be fixed and will report back if the problem is solved.
    Highlighted
    Was the missing pull-ups the issue?  I'm facing similar symptoms and we also forgot to add them to our board.
    EDIT: Adding the pullups fixed our problem.
    Highlighted
    Did someone of you have an example code with a modified driver code including STM32 devices using HAL library?
