    BHI160B example running on intel cpu with little endian
    Eyalb
    I am running the examples on intel cpu. the firmware is loaded OK and init is done OK, but it seems that bhy_enable_virtual_sensor is not doing the work.
    I see that once the fifo is emptied after init there is no more data in the fifo. I only get meta event 16.
    in bhy_initialize_from_rom the data written to BHI160 is reversed.
    maybe I need to reverse the data written in bhy_write_parameter_bytes ?
    Eyalb
    I found out that there is no need for swap.
