    BHI260AP HIRQ Always High
    grm
    Setup is BHI260AP using standard BHI260AP.fw.h firmware with the standard boilerplate configuration code.  Everything works as expected except that no matter what I do via the  bhy2_set_host_interrupt_ctrl() setup, edge or levels, the HIRQ pin remains high. Even if I flush all the FIFOs, the HIRQ remains high. It's as though it's still a GPIO input.
    Is there something obvious I'm missing in the configuration?
    Is there any way to test toggling the HIRQ pin?
    Is there any special firmware that can configure the pin as output low?
    Hi grm,
    You can use a logic analyzer to capture the changes in interrupt pin after power on. The interrupt pin is triggered by the rising edge and defaults to a low level.
    Have you correctly configured the interrupt function and service program on the host side? You should read FIFO instead of flush FIFO.
    Yes, I've tried all the above. Is there a backdor way I can toggle GPIO0 as an output or create a simple firmware file that just makes GPIO0 a low output?
    Hi grm,
    I upload example code on STM32 for your reference. Hope it will be helpful for you.
