01-17-2023 02:30 PM
Hello
BHI260AP is being implemented on the board.
I confirmed that I read the register such as i2c communication and chip id.
The error occurs while loading firmware as shown below.
(We changed the firmware name to the one we used before.)
root@imx8mmevk:/sys/class/input/input0# echo 1 > download_ram_firmware
[ 1085.740430] [D]<BHY><bhy2_store_download_ram_firmware><912>HAL request to load firmware
[ 1085.749135] [I]<BHY><bhy2_download_ram_firmware><825>fw name: ram_patch.bin
[ 1085.762468] [I]<BHY><bhy2_download_ram_firmware><831>fw data: 2B 66 00 00
[ 1085.769263] [I]<BHY><bhy2_download_ram_firmware><833>fw size: 106156
[ 1085.776879] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1086.776889] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1087.776886] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1088.776886] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1089.776886] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1090.776888] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1091.776888] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1092.776893] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1093.776887] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1094.776887] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1095.776887] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1096.776886] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1097.776889] [I]<BHY><bhy2_ts_sync_work_func><7461>Downloading firmware, not read HUB time
[ 1097.853680] [D]<BHY><bhy2_irq_control_setup><539>host int ctrl 0x04
[ 1098.014205] [D]<BHY><bhy2_upload_and_boot_ram_firmware><770>irq status is 0B after fw download
[ 1103.137678] [E]<BHY><bhy2_download_ram_firmware><878>No initialized meta event
[ 1103.145603] [E]<BHY><bhy2_store_download_ram_firmware><925>FW error is 0
[ 1103.159075] [D]<BHY><bhy2_dump_registers><185>dump register map:
[ 1103.165091] [D]<BHY><bhy2_dump_data><151>00 00 C0 04 00 00 00 00 00 00 00 00 00 00 00 00
[ 1103.173188] [D]<BHY><bhy2_dump_data><151>00 00 00 01 FF FF FF FF 89 03 2E 14 67 17 67 17
[ 1103.181284] [D]<BHY><bhy2_dump_data><151>4A 38 16 CC 04 00 00 70 00 0B 00 00 00 BF 00 00
[ 1103.189377] [D]<BHY><bhy2_dump_data><158>00 00 00 00 00 00 00 00 00 00
[ 1103.200958] [E]<BHY><bhy2_read_post_mortem_data><671>read post mortem failed ret=-6
[ 1103.208617] [D]<BHY><bhy2_dump_data><158>01 00 05 00
[ 1103.218704] [I]<BHY><bhy2_read_post_mortem_data><684>Request postmortem failed again 0xf
[ 1103.226798] [D]<BHY><bhy2_dump_data><158>01 00 05 00
[ 1103.231765] [E]<BHY><bhy2_store_download_ram_firmware><933>Try to read post mortem data failed
Since then, the log below has continued to appear.
[ 1140.787537] [E]<BHY><bhy2_enqueue_ring_buffer><64>One item lost due to data queue full
[ 1141.779610] [E]<BHY><bhy2_enqueue_ring_buffer><64>One item lost due to data queue full
[ 1142.779610] [E]<BHY><bhy2_enqueue_ring_buffer><64>One item lost due to data queue full
[ 1143.779603] [E]<BHY><bhy2_enqueue_ring_buffer><64>One item lost due to data queue full
Is there a sequence for firmware loading or if the way I did it is wrong?
04-12-2023 03:18 AM
Hi, BSTRobin
I want to check the communication waveform after checking only this last part.
I'm currently using a Linux Driver, but the file doesn't have a separate Firmware file,
so the Firmware file used the Firmware of the default BHI260AP Driver file as shown in the picture below.
Could this be a problem with the current error?
05-11-2023 05:07 AM
Hi mmgg,
The firmware should match your hardware. Could we know your haredware information first?
