    BM680 SENSOR, VOC RESULT GETTING PROBLEM
    hihith
    I already import in BSEC library in my code. (platform:IDE: Simplicity StudioMCU: EFM32LG332F128G-F-QFP64). However, after execute the "bsec_do_steps" routine, no VOC output result is found. The result is attached. (Remark: NO sensor id = '4' ,BSEC_OUTPUT_BREATH_VOC_EQUIVALENT)
    Thank!
    17 REPLIES 17
    Minhwan
    Re: BM680 SENSOR, VOC RESULT GETTING PROBLEM
    Hello hihith,
    If accuracy is 0, you can't get VOC result. Depending configuration, but if IAQ accuracy value is 3, that means the BME680 results are reliable. 3s interval configuration case, normally it takes around 20 mins. 300s requires more time because the calibration is based on data.
    Therefore, please let it go for a while, and check it if you can get temp and other sensors' value.
    Thanks 🙂
    hihith
    By the spec.of AN008-48.pdf, it mention output raw gas will affect the value of VOC.
    I have get the result as below:
    Condition: When i blow some air to the sensor, the gas is change, the voc and CO2 not change? Could you give me some advice?
    hihith
    Moreover , i have capture more than 1 hour, the IAR accuracy is always zero.
    Minhwan
    Hello Hihith,
    I could see IAQ accuracy was still 0.
    Are you using 3s or 300s interval? If you are using 300s, you should take more time.
    Normally, 3s interval requries 20~30mins.
    Thanks 🙂
