a month ago - last edited a month ago
We are using the BMA456 in a ground based sensor. The sensor spends most of the time asleep consuming as little power as possible. Once every hour it wakes from deep sleep makes some readings and sends them using LoRaWan protocol. We are using the BMA456 interrupt to wake up the sensor on an "Any Movement" interrupt. We are also looking to use the double tap interrupt to wake the sensor on demand to allow us to use service tools.
Currently when we wake from deepsleep (ESP32) it performs a "warm" reset, when this occurs we are reinitialising the BMA456 including reloading the configuration file. We are currently using BMA456MM feature set.
a month ago
Hi DalesLandnet ,
Thank for your inquiry.
BMA456 also supports any motion and double tap features in low-power mode without the need to reload firmware. When any motion or double tap events occur, the sensor will report an interrupt signal to the host to wake it up. Then the host read the interrupt status register of BMA456 to check which type of interrupt trigger (any motion, double tap, etc.) it is.
