    BMA Pin issue
    BMA Pin issue
    mgchoi
    Hi, bosch
    I use BMA 456 and I want to generate interrupt according to the vector value of the x,y,z axes. Initial completion and interrupt connection are checked, but Interrupt does not occur due to the X/Y/Z axis vector value change, so please guide me on what setting I need to make.
    config file is also down, and the current setting is set to active high in push pull.
    Inquiries: Code modification points for interrupt occurrence
    Current situation: Initial completion and Interrupt connection are confirmed, but Interrupt does not occur due to X/Y/Z axis vector value change
    Hi mgchoi,
    Have you referred to example code on github https://github.com/boschsensortec/BMA456-Sensor-API?
