Could you share your configuration part with me? 🙂
I'd like to check it.
@Minhwan wrote:Hello,
Sorry for late response.
I just want to check with you whether configuration, that may be inferred from attached archive, is sufficient to reproduce the issue:
I will be happy to provide more information if needed.
Here is an excerpt from on of the files:
ODR := 6.25 Hz, duation = 5 s
=== Get power mode configuration successful ===
adv_power_save = 1
=== Set power mode configuration successful ===
adv_power_save = 1
adv_power_save = 1
=== Get accelerator configuration successful ===
odr = 8
range = 1
bandwidth = 2
perf_mode = 1
=== Set accelerator configuration successful ===
odr = 4
range = 1
bandwidth = 2
perf_mode = 1
=== Internal status register ===
status = 0x1
odr = 4
range = 1
bandwidth = 2
perf_mode = 1
=== Get any-motion configuration successful ===
axis_en = 0x0
duration = 0x5
threshold = 0xaa
=== Get no-motion configuration successful ===
axis_en = 0x0
duration = 0x5
threshold = 0xaa
=== Set any-motion configuration successful ===
axis_en = 0x7
duration = 0x5
threshold = 0x400
=== Set no-motion configuration successful ===
axis_en = 0x7
duration = 0xfa
threshold = 0xcc
axis_en = 0x7
duration = 0x5
threshold = 0x400
axis_en = 0x7
duration = 0xfa
threshold = 0xcc
X := 8196, Y := 101, Z := -163
Shake the sensor in any direction
I just check your setting, and your threshold is quite high for test.
axis_en = 0x7
duration = 0x5
threshold = 0x400
Could you test with 0xAA ( default value)
Please check my test code and also would be great you share with your code like this.
