09-05-2022 02:13 PM
Hello support,
I am trying to make a BMA456 work at minimum through SPI bus. I send this list of command :
write 0xb6 in 0x7e
wait 500 ms
write 0x04 in 0x7d -> value check in the register OK
read 0x00 => return 0x16
write 0x00 in 0x41 => value check in the register OK
write 0x17 in 0x40 => value check in the register OK
I consult regularely :
register status 0x03 => always 0
register internal status 0x2a => always 0
What I missed in the configuration boar basic utilisation ? What I can check more ?
Thanks in advance
Mickael
09-11-2022 09:05 PM
I am porting your library on my micro. What is the meaning exactly of BMA456h, an, w ? Is it part number of the device noticed on it ? I dont see any reference like this in the reference guide of the device.
Thanks in advance
Mickael
09-14-2022 10:54 AM
Hi mlefores,
BMA456 had different sensor API version on github: https://github.com/BoschSensortec/BMA456-Sensor-API. Different versions support different features, and the corresponding configuration file sizes are different, can be flexibly selected for different applications..
bma456h supported features: any motion, no motion, step detector, step counter, step activity, auto low power, tap, single tap, double tap, triple tap.
bma456w supported features: any motion, no motion, step detector, step counter, step activity, single tap, double tap.
bma456an supported features: any motion, no motion.
2 weeks ago
Hello support,
I am still not able to use your device. I am facing strange problem on our custom hw design, after soft reset and wait 200ms, we have ERR_REG = 0x23 ... We are able to read temperature value but not able to have a positive result of selftest and its not possible to make a file config ...
Any idea ?
Thanks in advance
Mickael
