03-29-2022 03:43 PM
As per the example provided in the BSEC software for the config files to distinguish hand sanitizer and the field air the demo was carried out by me. The results are coming random according to that example. The % of hand sanitizer and field air is reversed at the beginning. On two devices the results are different. I am attaching the logs for reference.
03-30-2022 09:34 AM
Hi Ayashkant123,
Could we know more information about the software you used? Such as software version, link, etc.
By the way, which hardware platform you used?
03-30-2022 10:43 AM
https://github.com/BoschSensortec/Bosch-BSEC2-Library.git. Here in the examples/generic_examples/basic_config_state.ino examples hand sanitizer profile is present. I am using NRF-52832 dev kit with the BME688 module whereas NRF52832 chip and bme688 sensor with the hardware.
03-31-2022 03:53 PM
Hi Ayashkant123,
I'm using BME688 sensor with nRF52832 dev kit, too. I'm having some troubles using the APIs given by bosch https://github.com/BoschSensortec/BME68x-Sensor-API.
To make them work, I have to adapt the common.c file to nRF52832 standard, but I'm not sure if I make it all right. You should have done it, should you? Would you like to share the common.c file, please?
I would be very thankfull
04-22-2022 11:23 AM
Hi Ayashkant123,
Your previous log files indicated with different timestamp. Could you test the two device with same time and check them again?
