10-17-2020 11:48 AM
I found that if i use a UV LED flashlight against a BME280 temperature increase dramatically and humidity decrease the same way, instead pressure seems not affected.
BME 280 temperature & humidity
BME280 temperature, pressure & humidity
The spectrum of LED UV flashlight is this one, taken with an Ocean Optics USB2000+ UV spectrophotometer
LED UV flashlight spectrum
Is the sensor so sensible to UV light?
10-20-2020 04:19 AM
Is the UV light go directly into the hole of BME280?
If you cover the hole with black cover, is there still change of temperature and humidity?
10-20-2020 07:01 PM
Yes the UV light goes directly inside but I discovered that the UV flashlight warm all surfaces, also my skin. I don't know if it is an effect of UV or the flashlight has also an IR emission. White LED flash doesn't have this effect but I don't feel warm if I use it on my skin.
Anyway the graph shows that it is not a photoelectric effect since the warming and the cooling are not immediate.
10-20-2020 11:20 PM
We should avoid any direct light into sensor hole.
It will cause internal MEMS behavior goes to wrong like increased temperature slowly.
So please cover sensor and test again.
