Hi, I am integrating a BME680 with a TI CC1312 microcontroller. I can communicate fine with the sensor over I2C, from all appearances, but any time I am trying to take readings (even from the self-test from https://github.com/BoschSensortec/BME680_driver), I am getting no new data from the sensor. I have also tried a couple different units, getting the same results.
Here's some calibration info:
par_h1 unsigned short 717
par_h2 unsigned short 1022
par_h3 char 0 '\x00'
par_h4 char 45 '-'
par_h5 char 20 '\x14'
par_h6 unsigned char 120 'x'
par_h7 char -100 '\x9c'
par_gh1 char -47 '\xd1'
par_gh2 short -11597
par_gh3 char 18 '\x12'
par_t1 unsigned short 26045
par_t2 short 26419
par_t3 char 3 '\x03'
par_p1 unsigned short 36759
par_p2 short -10411
par_p3 char 88 'X'
par_p4 short 7301
par_p5 short -50
par_p6 char 30 '\x1e'
par_p7 char 51 '3'
par_p8 short -3768
par_p9 short -2137
par_p10 unsigned char 30 '\x1e'
t_fine int 0
res_heat_range unsigned char 1 '\x01'
res_heat_val char 47 '/'
range_sw_err char -1 '\xff'
And this is what comes out from the sensor when trying to read data:
[0] unsigned char 0 '\x00'
[1] unsigned char 0 '\x00'
[2] unsigned char 128 '\x80'
[3] unsigned char 0 '\x00'
[4] unsigned char 0 '\x00'
[5] unsigned char 128 '\x80'
[6] unsigned char 0 '\x00'
[7] unsigned char 0 '\x00'
[8] unsigned char 128 '\x80'
[9] unsigned char 0 '\x00'
[10] unsigned char 128 '\x80'
[11] unsigned char 0 '\x00'
[12] unsigned char 0 '\x00'
[13] unsigned char 0 '\x00'
[14] unsigned char 4 '\x04'
Any help appreciated!
Please share your code implementation here.
From the register value you posted, the measurement of sensor is not really happen, all result is 0.
Hi Vincent,
well, my code is essentially the self-test code from the Bosh GitHub.
I have created read/write i2c functions as well as delay, which appear to be working (I can read and write to registers, see calibration registers).
int8_t BME680::i2c_read(uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
uint8_t writeBuf[1] = {reg_addr};
i2cTransaction.readCount = len;
i2cTransaction.readBuf = reg_data;
i2cTransaction.writeCount = 1;
i2cTransaction.writeBuf = writeBuf;
bool status = I2C_transfer(i2c, &i2cTransaction);
return !status;
int8_t BME680::i2c_write(uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
i2cTransaction.readCount = 0;
i2cTransaction.writeCount = len;
i2cTransaction.writeBuf = reg_data;
return !status;
void BME680::delay(uint32_t delayMs) {
Task_sleep(delayMs*100); //fixme, must take into account actual duration of a tick (10us here)
Then in this case, can you try to read out whole register map of BME680 and provide here?
here's what I see (same order as they appear in the docs):
0xd0: 97
0x72: 0
0x74: 100
0x75: 0
0x50: 0
0x51: 0
0x52: 0
0x53: 0
0x54: 114
0x55: 0
0x56: 0
0x57: 0
0x58: 0
0x59: 0
0x5a: 0
0x5b: 0
0x5c: 0
0x5d: 0
0x5e: 0
0x5f: 0
0x60: 0
0x61: 0
0x62: 0
0x63: 0
0x64: 0
0x65: 0
0x66: 0
0x67: 0
0x68: 0
0x69: 0
0x6a: 0
0x6b: 0
0x6c: 0
0x6d: 0
0x70: 0
0x71: 0
0x1f: 128
0x20: 0
0x21: 0
0x22: 128
0x23: 0
0x24: 0
0x25: 128
0x26: 0
0x2a: 0
0x2b: 4
0x1d: 0
