06-30-2023 10:05 AM
Hi, BOSCH
The BME680 library file is currently in use by the gcc compiler.
The gcc compiler works without problems through the libalgobsec.a file provided on the homepage,
I'm trying to change to the arm compiler (MDK-ARM) for internal development, but I can't use the libalgobsec.a file.
If you add libalgobsec.a and compile it, the following error occurs,
You are in a situation where you need to proceed with additional operations, or you need another library file.
07-01-2023 04:25 PM
Hi mgchoi,
What is about your host platform information and which BSEC library you used?
07-03-2023 08:27 AM
We are using ARM Cortex M0+ And the library used the latest BSEC on BOSCH homepage.
07-03-2023 10:36 AM
编译中是否缺少某些内容?
07-06-2023 05:27 AM
The BSEC compiler part has been resolved.
However, I try to download the file of the previous version, but it does not download even if I receive a download link email.
We need all versions of the files below.
Is there any other way to download it?
