    BME680 gas resistanc no output
    rex
    My code is exactly the same as the code here,https://github.com/BoschSensortec/BME680_driver#example-for-reading-all-sensor-data
    But there is a issue, printf (", G: %d ohms", data.gas_resistance); there is no output
    Other data output is normal。
    Reading sensor data
    Example for reading all sensor data
        while(1)
            user_delay_ms(meas_period); /* Delay till the measurement is ready */
            printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
                data.pressure / 100.0f, data.humidity / 1000.0f );//normal
            /* Avoid using measurements from an unstable heating setup */
            if(data.status & BME680_GASM_VALID_MSK)
                printf(", G: %d ohms", data.gas_resistance);//no output
            printf("\r\n");
            /* Trigger the next measurement if you would like to read data out continuously */
            if (gas_sensor.power_mode == BME680_FORCED_MODE) {
    This is the data I read and write, I use i2c
    write to 0x76 ack data: 0x74
    read to 0x76 ack data: 0x8C
    write to 0x76 ack data: 0x74 0x8D
    write to 0x76 ack data: 0x1D
    read to 0x76 ack data: 0x80 0x00 0x51 0xF7 0x30 0x7B 0x0A 0x50 0x52 0xC5 0x80 0x00 0x00 0x3C 0xB6
    read to 0x76 ack data: 0x80 0x00 0x51 0xF7 0x30 0x7B 0x0A 0x40 0x52 0xC3 0x80 0x00 0x00 0x3B 0x36
    10 REPLIES 10
    rex
    Re: BME680 gas resistanc no output
    Can you give me some suggestions, thanks!
    Minhwan
    Hello rex,
    In github, there is configuration part as well.
    I would like to check your configuratoin part also.
    Could you upload your whole bme680 code?
    rex
    void bme680_task_process(void){
    twi_init_bme680(&twi_cfg_bme);
    struct bme680_dev gas_sensor;
    gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;
    gas_sensor.read = bme680_com_read;
    gas_sensor.write = bme680_com_write;
    gas_sensor.delay_ms = user_delay_ms;
    /* amb_temp can be set to 25 prior to configuring the gas sensor
    * or by performing a few temperature readings without operating the gas sensor.
    gas_sensor.amb_temp = 25;
    int8_t rslt = BME680_OK;
    //Regarding compensation functions for temperature, pressure, humidity and gas we have two implementations.
    //- Integer version
    //- floating point version
    //By default, Integer version is used in the API
    NRF_LOG_INFO("%s,id:%x\r\n",__FUNCTION__,gas_sensor.chip_id);
    //Example for configuring the sensor in forced mode
    /* Select the power mode */
    set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL | BME680_GAS_SENSOR_SEL;
    rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
    /* Set the power mode */
    //reading all sensor data
    /* Get the total measurement duration so as to sleep or wait till the
    * measurement is complete */
    uint16_t meas_period;
    char temperature[20];
    char pressure[20];
    char humidity[20];
    while(1)
    sprintf(temperature,"%f",data.temperature / 100.0f);
    NRF_LOG_INFO("%s,temperature:%s degC\r\n",__FUNCTION__,temperature); //normal
    sprintf(pressure,"%f",data.pressure / 100.0f);
    NRF_LOG_INFO("%s,pressure:%s hPa\r\n",__FUNCTION__,pressure); //normal
    sprintf(humidity,"%f",data.humidity / 1000.0f);
    NRF_LOG_INFO("%s,humidity:%s rH\r\n",__FUNCTION__,humidity); //normal
    //printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
    //data.pressure / 100.0f, data.humidity / 1000.0f );
    if(data.status & BME680_GASM_VALID_MSK){
    NRF_LOG_INFO("%s,gas_resistance:%d ohms\r\n",__FUNCTION__,data.gas_resistance); ////no output
    //printf(", G: %d ohms", data.gas_resistance);//气体电阻(欧姆)
    //printf("\r\n");
    gas_sensor.power_mode=BME680_FORCED_MODE;
    rex
    Hi, minhwan
    this is after the last task is run, the logic analyzer gets the data, thank you
    write to 0x76 ack data: 0xE0 0xB6
    write to 0x76 ack data: 0xD0
    read to 0x76 ack data: 0x61
    write to 0x76 ack data: 0x89
    read to 0x76 ack data: 0x80 0x4D 0x67 0x03 0x30 0x24 0x8D 0x90 0xD7 0x58 0x00 0xE4 0x1E 0x6E 0xFF 0x1F 0x1E 0x00 0x00 0x09 0xFB 0xA8 0xF3 0x1E 0x7F
    write to 0x76 ack data: 0xE1
    read to 0x76 ack data: 0x3F 0xE7 0x2C 0x00 0x2D 0x14 0x78 0x9C 0xC2 0x66 0xBD 0xE6 0xDF 0x12 0x9D 0x00
    write to 0x76 ack data: 0x02
    read to 0x76 ack data: 0x16
    write to 0x76 ack data: 0x00
    read to 0x76 ack data: 0x2F
    write to 0x76 ack data: 0x04
    read to 0x76 ack data: 0x03
    write to 0x76 ack data: 0x5A 0x41 0x64 0x65
    read to 0x76 ack data: 0x00
    write to 0x76 ack data: 0x75
    write to 0x76 ack data: 0x72
    write to 0x76 ack data: 0x71
    write to 0x76 ack data: 0x75 0x08 0x74 0x8C 0x72 0x02 0x71 0x10
    read to 0x76 ack data: 0x80 0x00 0x50 0xD6 0x80 0x78 0x8A 0x80 0x56 0xEE 0x80 0x00 0x00 0x2D 0xF5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x70 0x78 0x9F 0x00 0x57 0x01 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x50 0x78 0x9E 0x40 0x57 0x17 0x80 0x00 0x00 0x66 0xB5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x00 0x78 0x9D 0xA0 0x57 0x18 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9D 0x30 0x57 0x0A 0x80 0x00 0x00 0x66 0xB5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9D 0x00 0x56 0xF1 0x80 0x00 0x00 0x66 0x35
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x20 0x78 0x9C 0xC0 0x56 0xD4 0x80 0x00 0x00 0x64 0xF5
    read to 0x76 ack data: 0x80 0x00 0x50 0xDC 0x50 0x78 0x9C 0xC0 0x56 0xB8 0x80 0x00 0x00 0x65 0x75
