07-19-2023 09:41 PM
Are there recomended temperature and duration settings for the BME688, that will largely duplicate the response of other comparable VOC sensors?
Sensor part number "1": temperature X, duration Y
Sensor part number "2": temperature A, duration B
and so on. Specifically, what settings will duplicate the response of the the Sensirion SGP30 TVOC and eCO2 readouts?
It would be really cool if I could settle on just one sensor, and simply adjust the software to copy any other sensor...
07-22-2023 04:24 PM
Hi gdm528,
What gas do you want to detect?
07-22-2023 11:07 PM
My question is not specific to a particular gas, but to other gas sensors. For example, what BME688 settings will most closely duplicate the readings from a SGP30. From what I can divine from their datasheet, the SGP30 is sensitive to reducing gases: ethanol and H2.
Note that the SGP30 is discontinued, so does one replace it with another not-quite-the-same sensor from the same company, or 'clone' it with the BME688?
08-22-2023 11:49 AM
Similar question discussed in https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BME688-Heater-profile-theory-of-operatio...
