11-11-2022 09:54 AM
Hallo,
trying to compile firmware for the 8x dev kit as described in:
but running in the compilation issue:
Sketch uses 1375781 bytes (104%) of program storage space. Maximum is 1310720 bytes.
Global variables use 62800 bytes (19%) of dynamic memory, leaving 264880 bytes for local variables. Maximum is 327680 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board Adafruit ESP32 Feather.
Obviously, we are running out of the available HW resources.
Any suggestions?
11-12-2022 12:30 AM
Hi fritz,
Did you try to use our recommend version of library, not latest library.
Latest libraries have more size, and it causes out of size issue.
11-12-2022 06:21 PM
Hello Minhwan,
yes, I've used the recomended versions of the libraries as mentioned on the projects GIT readme page:
ArduinoJson (tested for 6.19.4 by Benoit Blanchon)
RTClib (tested for 2.0.3 by Adafruit)
SdFat (tested for 2.1.2 by Bill Greiman)
and ended up with 104% of program storage space.
There is only one newer version of mentioned libs available: RTClib verson 2.1.1.
Using this doesn't contribute to the overall program size significantly: +112 bytes
Sketch uses 1375893 bytes (104%) of program storage space.
BR's,
-fritz
11-17-2022 11:04 PM
Hi Fritz,
Then, it should work.
Could you check which board did you set?
It should be "Adafruit ESP32 Feather" in ESP32 Arduino.
11-18-2022 05:58 PM - edited 11-18-2022 06:12 PM
yes, "Adafruit ESP32 Feather" board is selected as a target platform.
Please see the detailed error message. You can see used libs and the target board:
"C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\xxx\\AppData\\Local\\Temp\\arduino_build_715919/bme68x_demo_sample.ino.bin" "C:\\Users\\xxx\\AppData\\Local\\Temp\\arduino_build_715919/bme68x_demo_sample.ino.elf"
esptool.py v4.2.1
Creating esp32 image...
Merged 25 ELF sections
Successfully created esp32 image.
"C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/gen_esp32part.exe" -q "C:\\Users\\xxx\\AppData\\Local\\Temp\\arduino_build_715919/partitions.csv" "C:\\Users\\xxx\\AppData\\Local\\Temp\\arduino_build_715919/bme68x_demo_sample.ino.partitions.bin"
Using library SdFat at version 2.1.2 in folder: C:\Users\xxx\Documents\Arduino\libraries\arduino_54829
Using library SPI at version 2.0.0 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\SPI
Using library RTClib at version 2.1.1 in folder: C:\Users\xxx\Documents\Arduino\libraries\RTClib
Using library Adafruit_BusIO at version 1.14.1 in folder: C:\Users\xxx\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 2.0.0 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\Wire
Using library Bosch-BSEC2-Library-master at version 1.1.2200 in folder: C:\Users\xxx\Documents\Arduino\libraries\Bosch-BSEC2-Library-master
Using library Bosch-BME68x-Library-master at version 1.1.40407 in folder: C:\Users\xxx\Documents\Arduino\libraries\Bosch-BME68x-Library-master
Using library ArduinoJson at version 6.19.4 in folder: C:\Users\xxx\Documents\Arduino\libraries\ArduinoJson
Using library BLE at version 2.0.0 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\BLE
"C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size" -A "C:\\Users\\xxx\\AppData\\Local\\Temp\\arduino_build_715919/bme68x_demo_sample.ino.elf"
Sketch uses 1376125 bytes (104%) of program storage space. Maximum is 1310720 bytes.
Global variables use 62824 bytes (19%) of dynamic memory, leaving 264856 bytes for local variables. Maximum is 327680 bytes.
text section exceeds available space in board
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
BR's
- fritz
