I have recorded some data using the BME688 dev-kit.
Once I uplaoded the data into BME AI Studio I can see a graph plotting the gaz or other sensor over time.
For the gaz channel I can see 10 different curves which looks similar but with and offset. I have 2 questions :
1 . What each plot correspond to? I don't think it s the different sensors as there are only eight and I have only selected sensor 1 on the example shown in the attached screenshot.
2. Once the model is trained is it possible to display again those plots ? if so how? from the .bmespecimen files ?
I have attached a screenshot.
Thanks for the feedback
Nicolas
Hello KejaPower,
1. Since for gas scanning, there are 10 heating steps with gas index from 0 to 9, so there are 10 different gas curves in plot;
2. After trained and put the config string into EKB, you needs to install the Demo APP(ready on web page) on android phone, then it will be ok to plot on the Demo APP.
