05-09-2024 01:20 PM - edited 05-09-2024 01:20 PM
Hi All,
I'm using a bme688 bosh sensor (Adafruit) with a Raspberrypi5.
I want to read sensor values from a java program.
Someone knows a java library for this sensor ?
Thank you for your help.
Florian.
05-09-2024 02:15 PM
BME688 BSEC 2 is a binary release (no source) and the PI is supported so you would need to use JNI to integrate.
There is a Python wrapper for BSEC 2 and you could push results to Java (via a queuing system like mosquito, or file system, etc) or broadcast via BLE and read on a seperate PI.
It all depends what you want to do and how much effort it will take.
Keith
05-09-2024 03:24 PM
Hi @kmca .
Thank you for your reply.
I just want obtain the BME688 temperature from a java program executed on RPI5.
05-11-2024 05:38 AM - edited 05-11-2024 05:57 AM
OK. Well you do not need BSEC to do that.
What you do need is an I2C library - PI4J perhaps to communicate with the BME688.
And read the data sheet and integration guide for formula.
The Adafruit BME680 Python code is pure python and works on the 688, so should give a template for a java implementation.
Regards
Update; it looks like this has already been done here:
Keith
05-14-2024 05:01 AM
Hi Flou1282,
The official BME688 API is based on the C language(https://github.com/boschsensortec/BME68x_SensorAPI), and you can refer to it, migrate it to your platform.
