    BMI085 GYRO_SELF_TEST Register Bit 4
    TKMS
    Dear Community,
    the datasheet says about the register 0x3c:
    A further test which is running continuously in the background can be checked by reading bit #4 in address GYRO_SELF_TEST. Proper sensor function is indicated if the bit is set to ‘1’.
    I always read "0" there while the data from Accel and Gyro is fine.
    I understood that this test runs continuously in background. So, whenever I read that register I expect a "1" to indicate proper functionality. I didn´t trigger the self test bit. The BMI085 runs at 200Hz, normal mode. Everthing is fine but I´d like to use that bit 4 as a safety check. Any ideas? Thank you!
    Jet
    Occasional Contributor
    Re: BMI085 GYRO_SELF_TEST Register Bit 4
    Hi Sir:
         Talked to our internal experts and further confirmed with API code, this bit only is another possibility and setting previously, currently it is no longer used .
         So I think it is not necessary for you to care it.
