01-30-2022 10:30 AM
Which terminals will be used for Spi4 wired connection? The picture of the sensor I am using is as follows. No terminal named (SA0) is defined in the datasheet file, but there is such a pin connection on the sensor. There is no such tip in the diagram given on page 103 of the datasheet file. Is this pin shown as SD0?
01-31-2022 08:16 PM
Yes, you are right. The SA0 pin on the breakout board is to select I2C slave address for BMI160. It is the same pin as BMI160 SDO pin-1 which can be used as MISO in SPI interface.
01-31-2022 09:40 PM
Thank you for your answer, but I missed it while looking at the BMI160 datasee. Page 89 is given in the table as you explained. I should have been a little more careful.
