07-10-2019 02:39 AM
Hello, reviewing the datasheet for the BMI160, it mentions in Page 12, under the block diagram that:
"The pre-filtered input data may be already temperature compensated or other low level correction operations may be applied to them."
Does this mean that the sensor data is already temperature calibrated on board the BMI160?
07-10-2019 02:08 PM
08-20-2019 05:36 AM
Hi o_o
(Feels odd to address you by emoji!)
Thanks for your response and apologies for the delay in my own reply post.
What I was trying to understand is whether any additional temperature compensation is required for the accelerometer readings, as I am planning to use the BMI160 to measure vibrations in an environment where the temperature may vary between 15°C to 40°C. It's not clear to me from the datasheet whether this is required and what the basis for such a compensation calculation would be.
08-20-2019 09:16 AM
Temperature will only affect the offset of the accelerometer. In vibration measurement, you are looking at the AC signal, not the DC component.
Therefore the temperature has no impact on that use-case
