    BMI160 interrupt to wake up MSP430FR6889 from low power sleep mode.
    Alex2hsrw
    I wrote this code with the expectation to enable interrupt functinality. I used a MSP430FR6889 with BMI160 where MSP430FR6889 is planned to operate in low power sleep mode. BMI160 should wake up MSP430 whenever there is any motion detection above defined threshold. This code doesnot work because when I move BMI160, I expect MSP430 to wake up and show data on console but i dont see anything.
    //Only Accel Woreking
    #include "driverlib.h"
    #include <gpio.h>
    #include <intrinsics.h>
    #include <msp430fr5xx_6xxgeneric.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <msp430.h>
    #define ACCEL_THRESHOLD 4000
    volatile int16_t accelValue = 0;
    //Address if the BMI160
    #define SLAVE_ADDR 0x69
    //Maximum I2C buffer size
    #define MAX_BUFFER_SIZE 20
    //Number of FFT samples
    #define SAMPLES 10
    //#define TimeStampSample 10
    #pragma PERSISTENT(input)
    int16_t input[SAMPLES] = {0}; //Store samples
    volatile uint32_t cycleCount;
    #define UP 0x0010 // Timer_A Up mode
    #define CONTINUOUS 0x0020 // Timer_A Continuous mode
    #define ACLK 0x0100 // Timer_A SMCLK source
    #define DEVELOPMENT 0x5A80 // Stop the watchdog timer
    #define BOUNCE_DELAY 0xA000 // Delay for Button Bounce
    #define MS_10 100 // Approximate value to count for 10ms
    #define SMCLK 0x0200 // Timer_A SMCLK source
    void timer_init(void)
    TA0CCTL0 = CCIE; //Enable counter interrupt
    TA0CCR0 = 0; //Initially stop Timer by starting at 0
    TA0CTL = TASSEL__SMCLK | MC__UP | ID__8; //Set clock source to ACLK, the count mode to Continuous, and the clock divider to 8
    TA0EX0 = TAIDEX_7; //Set expansion clock divider to 8
    TA1CCTL0 = CCIE; // TACCR0 interrupt enabled
    TA1CCR0 = 0; // Set count target to 0 by default
    // Set timer clock speed to 4.5898 ticks/s, or 16524 ticks/hour
    TA1CTL = TASSEL__ACLK | MC__STOP | ID__8; //Set clock source to ACLK, the count mode to Continuous, and the clock divider to 8
    TA1EX0 = TAIDEX_7; //Set expansion clock divider to 8
    int delay(int count)
    if(TA1CTL & TAIFG) // If Timer_1 is done counting
    count = count-1; // Decrement count
    TA1CTL = TA1CTL & (~TAIFG); // Reset Timer_1
    return count; // Return the value of count
    void UART_transmitString( char *pStr ) //Transmits a string over UART0
    while( *pStr )
    while(!(UCA0IFG&UCTXIFG));
    UCA0TXBUF = *pStr;
    pStr++;
    typedef enum I2C_ModeEnum{
    IDLE_MODE,
    NACK_MODE,
    TX_REG_ADDRESS_MODE,
    RX_REG_ADDRESS_MODE,
    TX_DATA_MODE,
    RX_DATA_MODE,
    SWITCH_TO_RX_MODE,
    SWITHC_TO_TX_MODE,
    TIMEOUT_MODE
    } I2C_Mode;
    I2C_Mode MasterMode = IDLE_MODE;
    uint8_t TransmitRegAddr = 0; //Register address for transmission
    uint8_t ReceiveBuffer[MAX_BUFFER_SIZE] = {0}; //Buffer for received values
    uint8_t RXByteCtr = 0; //Count received bytes
    uint8_t ReceiveIndex = 0; //Index of received data
    uint8_t TransmitBuffer[MAX_BUFFER_SIZE] = {0}; //Buffer for transmitted values
    uint8_t TXByteCtr = 0; //Count transmitted bytes
    uint8_t TransmitIndex = 0; //Index of transmitted data
    void CopyArray(uint8_t *source, uint8_t *dest, uint8_t count)
    uint8_t copyIndex = 0;
    for (copyIndex=0; copyIndex<count; copyIndex++)
    dest[copyIndex]=source[copyIndex];
    I2C_Mode I2C_Master_ReadReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t count)
    //printf("R\n");
    /* Initialize state machine */
    MasterMode = TX_REG_ADDRESS_MODE;
    TransmitRegAddr = reg_addr;
    RXByteCtr = count;
    TXByteCtr = 0;
    ReceiveIndex = 0;
    TransmitIndex = 0;
    /* Initialize slave address and interrupts */
    UCB1I2CSA = dev_addr;
    UCB1IFG &= ~(UCTXIFG + UCRXIFG); // Clear any pending interrupts
    UCB1IE &= ~UCRXIE; // Disable RX interrupt
    UCB1IE |= UCTXIE; // Enable TX interrupt
    UCB1CTLW0 |= UCTR + UCTXSTT; // I2C TX, start condition
    __bis_SR_register(LPM0_bits + GIE); // Enter LPM0 w/ interrupts
    // UCB1IE &= ~UCRXIE; // Disable RX interrupt
    return MasterMode;
    I2C_Mode I2C_Master_WriteReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t count)
    //Copy register data to TransmitBuffer
    CopyArray(reg_data, TransmitBuffer, count);
    TXByteCtr = count;
    RXByteCtr = 0;
    ReceiveIndex = 0;
    TransmitIndex = 0;
    //printf("W\n");
    return MasterMode;
    // BMI160 Functions ************************************************************
    void bmi160_init(char FOC_axis)
    uint8_t writeData[1];
    //Read Chip ID, which is D1
    I2C_Master_ReadReg(SLAVE_ADDR, 0x00, 1);
    if(ReceiveBuffer[0] != 0xD1)
    UART_transmitString(" Incorrect sensor chip ID ");
    printf("Incorrect sensor chip ID\n");
    //Configure the accelerometer
    writeData[0]=0b00101000; //Set acc_us to 0 for off, and acc_bwp must then be 010. Set acc_odr to 1011(800Hz),1100(1600Hz),1000(100Hz),0001(25/32Hz)
    I2C_Master_WriteReg(SLAVE_ADDR, 0x40, writeData, 1);
    //Check if configuration worked
    I2C_Master_ReadReg(SLAVE_ADDR, 0x40, 1);
    if(ReceiveBuffer[0] != writeData[0])
    UART_transmitString(" Accelerometer config failed ");
    printf("Accelerometer config failed\n");
    //Set the range of the accelerometer
    writeData[0]=0b1000; //0b0011 for 2g, 0b0101 for 4g, 0b1000 for 8g
    I2C_Master_WriteReg(SLAVE_ADDR, 0x41, writeData, 1);
    //Check if range is set
    I2C_Master_ReadReg(SLAVE_ADDR, 0x41, 1);
    UART_transmitString(" Accelerometer range set failed ");
    printf("Accelerometer range set failed\n");
    //Set the Accelerometer to normal power mode
    writeData[0] = 0x11;
    I2C_Master_WriteReg(SLAVE_ADDR, 0x7E, writeData, 1);
    //Read power mode status of sensors
    I2C_Master_ReadReg(SLAVE_ADDR, 0x03, 1);
    if(ReceiveBuffer[0] != 0x10)
    UART_transmitString(" Accelerometer not on ");
    printf("Accelerometer not on\n");
    void initGPIO()
    // I2C pins (P4.0 is SDA, P4.1 is SCL)
    P4SEL1 |= BIT0 | BIT1;
    P4SEL0 &= ~(BIT0 | BIT1);
    // Configure P3.4 and P3.5 to UART (Primary, TX and RX respectively) for NeoCortec
    P3SEL0 |= BIT4 | BIT5; // USCI_A1 UART operation
    P3SEL1 &= ~(BIT4 | BIT5); // SEL1 is 0 and SEL0 is 1 for primary operation, inverse for secondary
    // Configure P2.0 and P2.1 to UART (Primary, TX and RX respectively) for PC
    P2SEL0 |= BIT0 | BIT1; // USCI_A0 UART operation
    P2SEL1 &= ~(BIT0 | BIT1); // SEL1 is 0 and SEL0 is 1 for primary operation, inverse for secondary
    // Disable the GPIO power-on default high-impedance mode to activate
    // previously configured port settings
    PM5CTL0 &= ~LOCKLPM5;
    __bis_SR_register(GIE);
    void initClockTo16MHz()
    FRCTL0 = FRCTLPW | NWAITS_1;
    // Clock System Setup
    CSCTL0_H = CSKEY_H; // Unlock CS registers
    CSCTL1 = DCOFSEL_0; // Set DCO to 1MHz
    // Set SMCLK = MCLK = DCO, ACLK = VLOCLK (9.4kHz)
    CSCTL2 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK;
    // Per Device Errata set divider to 4 before changing frequency to
    // prevent out of spec operation from overshoot transient
    CSCTL3 = DIVA__4 | DIVS__4 | DIVM__4; // Set all corresponding clk sources to divide by 4 for errata
    CSCTL1 = DCOFSEL_4 | DCORSEL; // Set DCO to 16MHz
    // Delay by ~10us to let DCO settle. 60 cycles = 20 cycles buffer + (10us / (1/4MHz))
    __delay_cycles(60);
    CSCTL3 = DIVA__32 | DIVS__1 | DIVM__1; // Set ACLK to 239.75Hz, SMCLK to 16MHz, and MCLK to 16MHz
    CSCTL0_H = 0; // Lock CS registers
    void initI2C()
    UCB1CTLW0 = UCSWRST; // Enable SW reset
    UCB1CTLW0 |= UCMODE_3 | UCMST | UCSSEL__SMCLK | UCSYNC; // I2C master mode, SMCLK
    UCB1BRW = 160; // fSCL = ACLK/160 = ~100kHz
    UCB1I2CSA = SLAVE_ADDR; // Slave Address
    UCB1CTLW0 &= ~UCSWRST; // Clear SW reset, resume operation
    UCB1IE |= UCNACKIE;
    void UART_init(void)
    // Configure USCI_A1 for UART mode
    UCA1CTLW0 = UCSWRST; // Put eUSCI in reset
    UCA1CTLW0 |= UCSSEL__SMCLK; // CLK = SMCLK
    UCA1BR0 = 8; // Clock prescaler set to 8
    UCA1BR1 = 0x00; // High byte empty, low byte is 8
    UCA1MCTLW |= UCOS16 | UCBRF_10 | 0xF700; // Over-sampling on, first modulation register set to 10, second modulation register set to 0xF7 (247) for high byte, 0 for low byte
    UCA1CTLW0 &= ~UCSWRST; // Initialize eUSCI
    UCA1IE |= UCRXIE; // Enable USCI_A1 RX interrupt
    // Configure USCI_A0 for UART mode
    UCA0CTLW0 = UCSWRST; // Put eUSCI in reset
    UCA0CTLW0 |= UCSSEL__SMCLK; // CLK = SMCLK
    UCA0BR0 = 8; // Clock prescaler set to 8
    UCA0BR1 = 0x00; // High byte empty, low byte is 8
    UCA0MCTLW |= UCOS16 | UCBRF_10 | 0xF700; // Over-sampling on, first modulation register set to 10, second modulation register set to 0xF7 (247) for high byte, 0 for low byte
    UCA0CTLW0 &= ~UCSWRST; // Initialize eUSCI
    UCA0IE |= UCRXIE; // Enable USCI_A0 RX interrupt
    void goToSleep(void)
    // Enable global interrupts
    // Put MSP430 into LPM3 mode
    __bis_SR_register(LPM3_bits);
    // After waking up, the program continues from here
    int main(void)
    WDTCTL = WDTPW; // Stop watchdog timer
    //Initialize all peripherals
    initClockTo16MHz();
    initGPIO();
    UART_init();
    initI2C();
    timer_init();
    bmi160_init('Z');
    TA0CTL = TA0CTL | (SMCLK + CONTINUOUS); // SMCLK: Counts faster than ACLK
    TA0CCTL0 = CCIE; // Timer_0 interrupt
    TA1CTL = TA1CTL | (ACLK + UP ); // Count up from 0 with ACLK
    TA1CCR0 = MS_10; // Duration approximatley 10ms
    //_BIS_SR(GIE);
    int i=0;
    // Activate all interrupts
    while(1)
    { goToSleep();
    if (accelValue > ACCEL_THRESHOLD)
    // Display accelerometer value
    printf("Accelerometer value: %d\n", accelValue);
    printf("Reading samples\n");
    //Read SAMPLES amount of data from the BMI160
    for(i=0;i<SAMPLES;i++)
    I2C_Master_ReadReg(SLAVE_ADDR, 0x16, 2); //Read the acceleration value from the BMI160 registers
    input[i]= ReceiveBuffer[0] | (ReceiveBuffer[1] << 8); //Store the value in an array
    printf("%d\n", (unsigned)(input[i]));
    //I2C Interrupt
    #pragma vector = USCI_B1_VECTOR
    __interrupt void USCI_B1_ISR(void)
    //Must read from UCB1RXBUF
    uint8_t rx_val = 0;
    switch(__even_in_range(UCB1IV, USCI_I2C_UCBIT9IFG))
    case USCI_NONE: break; // Vector 0: No interrupts
    case USCI_I2C_UCALIFG: break; // Vector 2: ALIFG
    case USCI_I2C_UCNACKIFG: // Vector 4: NACKIFG
    UCB1CTLW0 |= UCTXSTT; // Re-send start if NACK
    break;
    case USCI_I2C_UCSTTIFG: break; // Vector 6: STTIFG
    case USCI_I2C_UCSTPIFG: break; // Vector 8: STPIFG
    case USCI_I2C_UCRXIFG3: break; // Vector 10: RXIFG3
    case USCI_I2C_UCTXIFG3: break; // Vector 12: TXIFG3
    case USCI_I2C_UCRXIFG2: break; // Vector 14: RXIFG2
    case USCI_I2C_UCTXIFG2: break; // Vector 16: TXIFG2
    case USCI_I2C_UCRXIFG1: break; // Vector 18: RXIFG1
    case USCI_I2C_UCTXIFG1: break; // Vector 20: TXIFG1
    case USCI_I2C_UCRXIFG0: // Vector 22: RXIFG0
    rx_val = UCB1RXBUF;
    if (RXByteCtr)
    ReceiveBuffer[ReceiveIndex++] = rx_val;
    RXByteCtr--;
    if (RXByteCtr == 1)
    UCB1CTLW0 |= UCTXSTP;
    else if (RXByteCtr == 0)
    UCB1IE &= ~UCRXIE;
    __bic_SR_register_on_exit(CPUOFF); // Exit LPM0
    break;
    case USCI_I2C_UCTXIFG0: // Vector 24: TXIFG0
    switch (MasterMode)
    case TX_REG_ADDRESS_MODE:
    UCB1TXBUF = TransmitRegAddr;
    if (RXByteCtr)
    MasterMode = SWITCH_TO_RX_MODE; // Need to start receiving now
    else
    MasterMode = TX_DATA_MODE; // Continue to transmision with the data in Transmit Buffer
    break;
    case SWITCH_TO_RX_MODE:
    UCB1IE |= UCRXIE; // Enable RX interrupt
    UCB1IE &= ~UCTXIE; // Disable TX interrupt
    UCB1CTLW0 &= ~UCTR; // Switch to receiver
    MasterMode = RX_DATA_MODE; // State state is to receive data
    UCB1CTLW0 |= UCTXSTT; // Send repeated start
    if (RXByteCtr == 1)
    //Must send stop since this is the N-1 byte
    while((UCB1CTLW0 & UCTXSTT));
    UCB1CTLW0 |= UCTXSTP; // Send stop condition
    break;
    case TX_DATA_MODE:
    if (TXByteCtr)
    UCB1TXBUF = TransmitBuffer[TransmitIndex++];
    TXByteCtr--;
    else
    //Done with transmission
    UCB1IE &= ~UCTXIE; // disable TX interrupt
    break;
    default:
    __no_operation();
    break;
    break;
    default: break;
    #pragma vector = TIMER0_A0_VECTOR
    __interrupt void Timer_A0_ISR(void)
    // Read accelerometer value
    accelValue = ReceiveBuffer[0] | (ReceiveBuffer[1] << 8);
    printf("Interrupt value: %d\n", accelValue);
    // Wake up the MSP430
    __bic_SR_register_on_exit(LPM3_bits);
    FAE_CA1
    Please check the topic at https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/Reducing-BMI160-Power-Consumption-Below-... about how to use BMI160 low power mode for any-motion interrupt to wake up the host processor.
