    BMI160 some FIFO frames contain the same value for x, y and z
    AlexC
    We are seeing a strange issue where every other call to bmi160_get_fifo_data returns a set of frames where each frame has the same values for x, y and z.
    For example: x = -17024    y = -17024    z = -17024
    We currently get from the FIFO every second, the curret setup for the accelerometer is:
    ODR: 25HZ
    Range: 16G
    BW: NORMAL_AVG4
    power mode: Normal
    I would greatly appreciate any help in why this may be happening.
    Thank you in advance!
    2 REPLIES 2
    kgoveas
    Re: BMI160 some FIFO frames contain the same value for x, y and z
    Hi  AlexC,
    Assuming you are using the BMI160 Sensor driver off our Github page, can you share the API calls until the bmi160_get_fifo_data?
    Thanks and regards,
    kgoveas
    AlexC
    Hi kgoveas,
    Thanks for your reply, Im afraid I realised im stupid mid way through replying to you.
    So we are using 2 BMI160 of course they are named differently and one is in low power mode, so  I was trying to read from the FIFO on the low power accelerometer. Which because of the way low power mode works of course would return weird values if its not doing anything.
    Many thanks for your help!
