05-09-2024 11:52 AM
Hi i am a fresher in development and I am trying to get only gyroscope data from BMI270 sensor. Initially I have tried to get the data from example code from github - boschsensortec /BMI270_SensorAPI , I tried to build - bmi270_examples/gyro/gyro.c . I got error that COINES is not included later i included COINES package as well and set the directory path correctly . Even though I didnot get any data .
Hardware wise I am only using BMI270 and I have made the connections to microprocessor as per the documentaion of 4 wire SPI .
so i want to get more clarification how to get data from BMI270
- does it require any other hardware like Application board or shuttle board .
- does the sensor require any configuration through software , if so , please list down them with thier dependicies.
- can we build the cdoe without using COINES package .
- or list any other way of getting gyro data from sensor using C code without external dependicies.
05-14-2024 04:57 AM
Hi manivt,
If you want to use COINES code directly, you need the APP 3.0 board and the BMI270 Shuttle board 3.0
If you don't have an APP 3.0 board and a BMI270 Shuttle Board 3.0 board, you can refer to the BMI270 sensor API and examples on Github(https://github.com/boschsensortec/BMI270_SensorAPI) and migrate them to your host hardware.
I also uploaed BMI270 example code on STM32 for your reference, hope it will be helpful for you.
05-14-2024 07:36 AM
Thanks for the response , I have earlier tried using github example code ( boschsensortec/BMI270_SensorAPI/bmi270_examples/gyro ) and I have inculded all the required depedencies .
In Make of gyro it is asking for path for COINES but i want to use the sensor without COINES
COINES_INSTALL_PATH ?= ../../../..
EXAMPLE_FILE ?= gyro.c
API_LOCATION ?= ../..
COMMON_LOCATION ?= ..
C_SRCS += \
$(API_LOCATION)/bmi2.c \
$(API_LOCATION)/bmi270.c \
$(COMMON_LOCATION)/common/common.c
INCLUDEPATHS += \
$(API_LOCATION) \
include $(COINES_INSTALL_PATH)/coines.mk
- Can I remove COINES path and its code file and use the code
- Or am I using the wrong example code for using the sensor
- Do I have to make any changes in code to make sensor work
05-14-2024 08:26 AM
Hi manivt,
If you would like to run BMI270 sensor API and examples on your own host & BMI270 hardware, you don't need code related to Coines, replace it with code from your host platform.
05-18-2024 09:45 AM
can you list me down where do need to make changes on code to make example code running
