Wednesday
I have several BMI323 semsors need to be connected in serial on I2C so I have to set each of them with different addresses. I didn't find any info in library or from data sheet. I noticed BOSCH mentioned "Each sensor can be set to a unique I2C address, as described in the hardware description in the data sheet." Could you share some info where and how I can implement the re-addressing of them? THX!
Monday
Hi kaosun,
Do you have engouh IO? I think you can use IO to simulate the i2c read/write. So you can use the same address, use GPIO to distinguish different sersors.
