    BMI323 fails to start feature engine, acc or gyro. Only reads 0x8000
    tobbeanton
    I'm building my own board with a BMI323. I tripple checked the connections, everything seams fine. I've tried resoldering 3 different BMI323 all with the same result. I'm using the latest offical bmi3 github drivers and all the three BMI323 answeres the correct chip ID but fails when soft-resetting and trying to start the feature engine.
    BMI323 CAD:ed like this:
    I've taken some I2C logs where I ignore the BMI3_E_FEATURE_ENGINE_STATUS error so I can also configure and read the acc+gyro both with a 0x8000 response on all axis:
    write to 0x68 ack data: 0x7E
    write to 0x68 ack data: 0xAF 0xDE
    write to 0x68 ack data: 0x12
    write to 0x68 ack data: 0x2C 0x01
    write to 0x68 ack data: 0x14
    write to 0x68 ack data: 0x01 0x00
    write to 0x68 ack data: 0x40
    write to 0x68 ack data: 0x11
    read to 0x68 ack data: 0x00 0x00 0x00 0x00
    write to 0x68 ack data: 0x00
    read to 0x68 ack data: 0x00 0x00 0x43 0x11
    write to 0x68 ack data: 0x41
    write to 0x68 ack data: 0x05 0x00
    write to 0x68 ack data: 0x42
    write to 0x68 ack data: 0x08 0x10 0x05 0x00 0xFA 0xA0
    write to 0x68 ack data: 0x08 0x00
    write to 0x68 ack data: 0x1E 0x10 0x03 0x00 0xFA 0xA0
    write to 0x68 ack data: 0x1E 0x00
    write to 0x68 ack data: 0xB6 0x00 0xFA 0x64 0x64 0x68
    write to 0x68 ack data: 0x10 0x00
    write to 0x68 ack data: 0x00 0x00 0x33 0x01 0xEC 0xF1 0x50 0x00 0x9A 0xD9 0x7E 0xF6 0x66 0xE6 0x14 0x20 0x0F 0x0E 0xC3 0xF3 0x96 0xA0 0x57 0x0D
    write to 0x68 ack data: 0x0D 0x00
    write to 0x68 ack data: 0xFA 0x00 0x96 0x20 0x53 0x46
    write to 0x68 ack data: 0x1C 0x00
    write to 0x68 ack data: 0xD8 0x54 0x32 0x20
    write to 0x68 ack data: 0x21
    read to 0x68 ack data: 0x00 0x00 0x48 0x00
    write to 0x68 ack data: 0x3A
    read to 0x68 ack data: 0x00 0x00 0x00 0x00 0x00 0x00
    write to 0x68 ack data: 0x00 0x00 0x00 0x01
    write to 0x68 ack data: 0x48 0x40
    write to 0x68 ack data: 0x03
    read to 0x68 ack data: 0x00 0x00 0x00 0x80 0x00 0x80 0x00 0x80 0x00 0x80 0x00 0x80 0x00 0x80 0x00 0x80 0x14 0x07 0x00 0x00 0x00 0x00
    I2C communication looks fine:
    What am I doing wrong?
    7 REPLIES 7
    Hi and thank you for the reply. We switched to LSM6DS3 so I will first have a look at this when I got some time over.
    Hey,
    Did you check? Im also having the issue, where after receiving the chip id 43 the soft reset command is sent, but then it times out with error state -14. I used the example code provided here.
    I'm having the same error. Unfortunately, writing operations to IC is not successful even if I use logic analyser hardware to do this. Could someone from Bosh help please?
    Mehmet
