09-22-2023 08:54 AM
Our company is evaluating a Bosch Sensortec BHI360+BMM350 combination for a 9-axis IMU.
However we noticed that the CRST capacitor ( 2.2uF non-magnetic, low ESL/ESR) required in the BMM350 datasheet is End of Life with a last ship date in a year from now. Do you have other alternatives to this component?
Without qualified options (preferrably 2 different for supply sequrity), no-one can really design in your magnetometers..?
10-04-2023 10:58 AM
Hi svend,
We will check it and give you feedback later.
10-07-2023 05:22 AM
Hi svend,
Two substituted components are recommended.
(1) Murata GRM216R61A225KE24D is 0805size, low height 0.6 ±0.1 mm (but it is NRND= Not recommended for new design, although it is in production), in stock.
(2) TDK C1005X5R1A225K050BC is 0402size, low height 0.55mm, in stock.
