06-23-2023 10:03 PM
I am looking to use this sensor outside of the operating range for pressure (i.e., <300hPa). I understand that since it would be outside of the range, its accuracy would not be guaranteed. However, if it were to be exposed to a low pressure (~147hPa) and then fall within the operational range again, would it still maintain its accuracy within the operational range or would taking it outside of the range potentially damage it and not allow it to give accurate readings within this range?
06-24-2023 05:21 PM
Hi rmichaels27,
Low pressure (~147hPa) is outside of the range, its accuracy would not be guaranteed. But the sensor can work normally and will not be damaged.
As it fall within the operational range again, would it still maintain its accuracy within the operational range.
