    BMP390 configuration error when setting OSR
    Kisle
    Hi all,
    I am using a BMP390 and measuring works fine in standard configuration. I can switch to normal mode and fetch proper measurements.
    However, as soon as I try to set the OSR register the BMP390 goes into an "configuration error" state and switches to sleep mode and then i am unable to activate normal mode again. A soft reset cmd will restore the defaults and fixes this. However OSR is also reset then.
    The datasheet didnt really clarify to me what is happening exactly. I tried different OSR configurations, I dont see what could be wrong with any of those. Are there any configurations that are not allowed or have to be set together?
    Best regards
    Mark
    2 REPLIES 2
    Kisle
    Ok it seems when setting oversampling then the odr_sel has to be configured accordingly. 2x oversamping requires 2x prescaler on odr_sel.
    Hi Kisle,
    Thank for your inquiry.
    You can set BMP390 sensor configuration according the description in data sheet.
    You can also refer to official BMP390 example code: https://github.com/boschsensortec/BMP3_SensorAPI/tree/master/examples
