09-25-2023 11:34 AM
Hello everyone,
what is the frequency at which the BMP390L samples during oversampling?
Thank you, Daniele.
09-25-2023 04:48 PM
Hi daniele90,
There was no the part number BMP390L. Do you mean you are using BMP390? Could we know what is your application like and requirement? The new recommended pressure sensor is BMP581, BMP585.
09-26-2023 09:28 AM
Yes, I meant the BMP390. We're utilizing it for indoor navigation, following the recommended settings from the datasheet: 16x oversampling for pressure, 2x oversampling for temperature, and an output data rate of 25 Hz. My understanding is that 16x oversampling implies the sensor samples data 16 times and then provides the average value. However, I'm curious about the frequency at which these samples are taken.
Daniele
10-17-2023 10:31 AM
does anyone know at what frequency the BMP390 performs oversampling?
Daniele
3 weeks ago
Hi daniele90,
Sample rate is 200 Hz in BMP390 data sheet.
