    BMX160/BMI160 no fifo interrupt
    André
    I can't figure out why the bmx160/bmi160 is not generating any fifo watermark interrupt while it does generated any motion interrupts.
    Here is a dump of all the 85 registers of the bmx160 :
    0s024:###### BMX160 regs offset = 0x00 -> d8 21  0 10  0  0  0  0  0  0  0  0  0  0  0  0
    0s125:###### BMX160 regs offset = 0x10 ->  0  0 8f f2 fc fb 4d c5 f3 9c 9c 10  0  0  0  0
    0s227:###### BMX160 regs offset = 0x20 -> 93 f2 2d  1 84 8b f2  4 fc 94 c5 84 86 f2 29 fc
    0s329:###### BMX160 regs offset = 0x30 ->  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    0s430:###### BMX160 regs offset = 0x40 -> 29  3  8  0  b 88 64 52  0  0  0 20 80 42 4c  0
    0s532:###### BMX160 regs offset = 0x50 ->  7 40  0 a9  8  0 40  4  0  0  7 30 81  b c0  0
    0s633:###### BMX160 regs offset = 0x60 ->  e 14 24  4  a 18 48  8 11  0  0  0  0  0  0  0
    0s735:###### BMX160 regs offset = 0x70 ->  0  0  0  0 3f a7  6  0  0  0 15  3  0  0  0  0
    0s836:###### BMX160 regs offset = 0x80 -> d8 21  0 10  0  0  0  0  0  0  0  0  0  0  0  0
    any help is greatly appriciated!!!!
    here is the code used :
    uint8_t Open_BMI160_ANY_MOTION(struct bmi160_dev *dev, uint8_t latch_dur, enum bmi160_int_channel int_channel) {
    uint8_t rslt;
    int_config.int_channel = int_channel; //BMI160_INT_CHANNEL_2;// Interrupt channel/pin 1
    int_config.int_type = BMI160_ACC_ANY_MOTION_INT;// Choosing Any motion interrupt
    int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
    int_config.int_pin_settg.output_type = BMI160_ENABLE;// Choosing active high output
    int_config.int_pin_settg.edge_ctrl = BMI160_DISABLE;// Choosing edge triggered output
    int_config.int_pin_settg.latch_dur = latch_dur;  //// non-latched output
    /* Select the Any-motion interrupt parameters */
    int_config.int_type_cfg.acc_any_motion_int.anymotion_en = BMI160_ENABLE;// 1- Enable the any-motion, 0- disable any-motion
    int_config.int_type_cfg.acc_any_motion_int.anymotion_x = BMI160_ENABLE;// Enabling x-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_y = BMI160_ENABLE;// Enabling y-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_z = BMI160_ENABLE;// Enabling z-axis for any motion interrupt
    // any duration is anymotion_dur * 1 / ODR so 8 * 1 / 400 == 1/100 == 20 mS
    int_config.int_type_cfg.acc_any_motion_int.anymotion_dur = ANYMOTION_DURATION;// any-motion duration
    int_config.int_type_cfg.acc_any_motion_int.anymotion_thr = ANYMOTION_THRESHOLD;
    rslt = bmi160_set_int_config(&int_config, dev);
    return rslt;
    int8_t Open_BMI160_DRDY(struct bmi160_dev *dev, int enable,  enum bmi160_int_channel int_channel)
    int8_t rslt = BMI160_OK;
    int_config.int_channel = int_channel; // BMI160_INT_CHANNEL_1;// Interrupt channel/pin 2
    if (enable != 0 ) {
    int_config.int_type = BMI160_ACC_GYRO_DATA_RDY_INT;// Choosing interrupt
    } else {
    int_config.int_type = 0;// Choosing interrupt
    int_config.int_pin_settg.output_type = BMI160_DISABLE;// Choosing active high output
    int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing edge triggered output
    int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_312_5_MICRO_SEC;// non-latched output
    //int_config.fifo_wtm_int_en = BMI160_ENABLE;//Enable FIFO watermark interrupt
    /* Set the FIFO watermark interrupt */
    return rslt;
    int8_t Open_BMI160_FIFO(struct bmi160_dev *dev, uint8_t fwm, enum bmi160_int_channel int_channel)
    fifo_frame.data = fifo_buff;
    fifo_frame.length = FIFO_SIZE;
    dev->fifo = &fifo_frame;
    /* Clear FIFO configuration register */
    rslt = bmi160_set_fifo_config(BMI160_FIFO_CONFIG_1_MASK, BMI160_DISABLE, dev);
    if (rslt != BMI160_OK)
    APP_LOG(TS_ON, VLEVEL_M, "Clear FIFO configuration register error, error code: %d\r\n", rslt);
    return rslt;
    // 400Hz : 1024 bytes fifo buffer holds 1024/7 = 146 samples of 7 bytes, set watermark at 80%
    // means watermark is 117, make it 100 drames
    // Avk set watermark level to 20 entries
    rslt = bmi160_set_fifo_wm( fwm /*100 */, dev);//7*50=350 bytes, water mark value was word unit, cann't be greater than 255, 87*4=348
    if(rslt != BMI160_OK)
    APP_LOG(TS_ON, VLEVEL_M,"bmi160_set_fifo_wm error, error code: %d\r\n", rslt);
    // BMI160_FIFO_A_ENABLE enable fifo for accelerometer only
    rslt = bmi160_set_fifo_config(/*BMI160_FIFO_A_ENABLE |BMI160_FIFO_TAG_INT1 */
    BMI160_FIFO_ACCEL|BMI160_FIFO_HEADER|BMI160_FIFO_TIME, BMI160_ENABLE, dev);
    APP_LOG(TS_ON, VLEVEL_M,"bmi160_set_fifo_config error, error code: %d\r\n", rslt);
    /* Flush FIFO */
    rslt = bmi160_set_fifo_flush(dev);
    APP_LOG(TS_ON, VLEVEL_M, "Flush FIFO error, error code: %d\r\n", rslt);
       return rslt;
    int_config.int_type = BMI160_ACC_GYRO_FIFO_WATERMARK_INT;// Choosing interrupt
    int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
    return rslt;
    int8_t Close_BMI160_FIFO(struct bmi160_dev *dev)
    return rslt;
    int8_t Open_BMI160_ACC(struct bmi160_dev *dev)
    /* Select the Output data rate, range of accelerometer sensor */
    dev->accel_cfg.odr = 0x09; // 200Hz
    dev->accel_cfg.range = BMI160_ACCEL_RANGE_2G;
    // TODO: dev->accel_cfg.power = BMI160_ACCEL_LOWPOWER_MODE;
    dev->accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
    dev->gyro_cfg.power = BMI160_GYRO_SUSPEND_MODE;
    rslt = bmi160_set_sens_conf(dev);
    //PDEBUG("bmi160_set_sens_conf rslt=%d\r\n", rslt);
    return rslt;
    int8_t BMX160_Init(void)
    struct bmi160_dev *dev = &bmi160dev;
    dev->intf = BMI160_I2C_INTF;
    dev->id =  BMI160_I2C_ADDR;
      dev->read = SensorAPI_I2Cx_Read;
      dev->write = SensorAPI_I2Cx_Write;
    dev->delay_ms = HAL_Delay;
    dev->read_write_len = 32; // never used in driver???
    rslt = Open_BMI160_ACC(dev);
    if ( rslt != BMI160_OK ) {
    return rslt;
    rslt = Open_BMI160_FIFO(dev, FWM_LEVEL, BMI160_INT_CHANNEL_1);
    return rslt;
    rslt = Open_BMI160_ANY_MOTION(dev, BMI160_LATCH_DUR_40_MILLI_SEC, BMI160_INT_CHANNEL_2);
    return rslt;
    print_all_bmx_regs(dev);
    return rslt;
    Hi André,
    Do you mean your host don't receive any interrupt from INT1?
    What is FWM_LEVEL value in your code?
    How is the implement of interrupt service handler?
    André
    Yes!
    100
    I check it with a scope for now
    Not yet implemented, check it with a scope on INT1 pin directly and I dont see any activity
    I hope that the register dump can help finding the problem.
    Cheers
    Hi André,
    water mark value was word unit, 100 means 100*4=400 bytes FIFO data. Water mark interrupt will be triggled every 400/7=57 frame data.
    I upload example code for your reference, enable macro definition in the file user_define.h.
    #if defined(USE_BMI160)
    #define ACC_ONLY
    //#define GYRO_ONLY
    //#define ACC_GYRO
    //#define USE_EXT_BMM150
    //#define DATA_POLL
    //#define TAP
    //#define NO_MOTION
    //#define STEP_COUNTER
    //#define FIFO_POLL
    #define FIFO_WM_INT
    #endif
