    BNO055 Offset readings
    jspear16
    Hello Bosch Community,
    Hopefully this is a simple question, but I am trying to read out my magnetometer and gyroscope offset values, and they are not changing when the device is moved, power cycled, re-programmed, etc. Is this supposed to be the case?
    I am in NDOF mode at the time of reading. I have also attempted to read while in CONFIG mode, and they are the same values. I have never tried to write any offset values.
    Furthermore, if anyone can explain the offset readings that would be helpful. I have read over the datasheet, but I am still confused on the exact purpose/use of the offsets.
    Thank you in advance.
    Re: BNO055 Offset readings
    Hello jspear16,
    You could refer the following description in data sheet to read calibaration profile.
