    BNO055 USB Stick UART protocol does not match datasheet
    kgoveas
    Re: BNO055 USB Stick UART protocol does not match datasheet
    Hi Jason,
    Is there any specific feature(s) you would like to evaluate using the BNO055 USB stick?
    Jason
    Yes, as an IMU, I am not sure I understand your question.   Basically I need to evaluate it as part of a larger Linux system performing all sorts of different functions and having orientation, etc it one of the requirements.
    Right now I am looking at buying the version that connect to the Arduino and just use it over I2C but it would have been nice to know ahead of time that the datahseet was incorrect that we could just write our own serial driver protocol to integrate it into our system.
    We like the IMU functionality seen in the software now we just need to make it work in our system.
    Jason
    skypuppy
    Jason, you can get the BNO055 in a non-USB format from many vendors.  They have an I2C and IIRC a couple other bus types.  There is another vendor in Switzerland that has a USB type BNO055 as well as Bosch's called Yoctopuce.  I don't know if is actually the same board as Bosch makes.  Bear in mind that the software for the I2C bus and such was too difficult for me to write, even using the Bosch-supplied C stubs.  It's a maze of twisty passages all different.
    My target was a Raspberry Pi (RPi.)  If that's of any help to you.
    Vincent
    The COINES version under Linux do NOT support BNO USB stick right now.
    The current way to evalute it is using generic API under windows or directly throug the DD2.0 to run with this USB stick.
    If you want to use BNO055 under Linux, you can try BNO055 shuttle with break out board for existing Linux platform.
    KWolfe81
    Sorry to dig up an old thread.  Thank you for providing the Generic API.  I would like to use the DLL in a .NET application.  Could you also supply the appropriate & matching header (.h) file?
