08-05-2024 05:01 PM
Hi everyone,
For days, I have had a problem initializing the BNO055 IMU sensor with the ESP32. After troubleshooting , here is the output of i2c tool? This always causes a blockage in reading and writing to the sensor.
Note that I am using esp-idf, and when i tried the same hardware with Arduino IDE, it worked perfectly.
Also here is a snippet of my code:
BNO055_RETURN_FUNCTION_TYPE BNO055_I2C_bus_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t cnt)
int comres = 0; // Result of communication
i2c_cmd_handle_t cmd = i2c_cmd_link_create();
// Start transmission
i2c_master_start(cmd);
// Send device address and write bit
i2c_master_write_byte(cmd, (dev_addr << 1) | I2C_MASTER_WRITE, ACK_CHECK_EN);
// Send the register address
i2c_master_write_byte(cmd, reg_addr, ACK_CHECK_EN);
// Stop transmission
i2c_master_stop(cmd);
esp_err_t ret = i2c_master_cmd_begin(I2C_MASTER_NUM, cmd, pdMS_TO_TICKS(1000));
i2c_cmd_link_delete(cmd);
if (ret != ESP_OK) {
ESP_LOGE(TAG, "I2C Write failed");
return -1; // Communication failure
// Small delay to ensure data is ready
esp_rom_delay_us(150);
// Create new command for reading data
// Send device address and read bit
i2c_master_write_byte(cmd, (dev_addr << 1) | I2C_MASTER_READ, ACK_CHECK_EN);
// Read the data
if (cnt > 1) {
i2c_master_read(cmd, reg_data, cnt - 1, ACK_VAL);
i2c_master_read_byte(cmd, reg_data + cnt - 1, NACK_VAL);
ESP_LOGE(TAG, "I2C Read failed");
return -1;
return comres;
BNO055_RETURN_FUNCTION_TYPE BNO055_I2C_bus_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t cnt)
BNO055_RETURN_FUNCTION_TYPE comres = 0; // Result of communication
// Write the data
for (uint8_t index = 0; index < cnt; index++) {
i2c_master_write_byte(cmd, reg_data[index], ACK_CHECK_EN);
// Small delay to ensure data is written
return comres;
void bno055_task(void *pvParameter) {
struct bno055_t bno055 = {
.bus_read = BNO055_I2C_bus_read,
.bus_write = BNO055_I2C_bus_write,
.dev_addr = 0x29,
.delay_msec = _delay
BNO055_RETURN_FUNCTION_TYPE com_rslt;
struct bno055_accel_t accel_data;
bool sensor_ready = false;
// Initialize BNO055 sensor
com_rslt = bno055_init(&bno055);
if (com_rslt == BNO055_SUCCESS) {
// Set operation mode
com_rslt = bno055_set_operation_mode(BNO055_OPERATION_MODE_NDOF);
sensor_ready = true;
} else {
ESP_LOGE(TAG, "BNO055 set operation mode failed with code: %d", com_rslt);
} else {
ESP_LOGE(TAG, "BNO055 initialization failed with code: %d", com_rslt);
while (1) {
if (sensor_ready) {
// Read Euler angles with error handling
com_rslt = bno055_read_accel_xyz(&accel_data);
ESP_LOGI(TAG, "Accel X: %d, Y: %d, Z: %d", accel_data.x, accel_data.y, accel_data.z);
else
ESP_LOGE(TAG, "BNO055 read accel failed with code: %d", com_rslt);
vTaskDelay(100); // Adjust delay as needed
And this is the output:
Any help or comment would be appreciated.
