04-01-2024 02:41 PM
We are working with BHI 360 – Shuttle board 3.0. Interfacing it with STM development board via I2C using TXS108 IC, didn't getting any resonse fron the Shuttle Board. We not using any external pull_up for SCL & SDA as TXS108 contains internal 10k pull_up on both side.
04-03-2024 03:20 AM
Hi Deepak_,
About TXS108 IC, as seen on TI's official website: firstly, the TXS010x series level converter devices can be used for I2C and SPI applications. However, due to their weak DC drive capability (20uA), it is not recommended to use such devices if the PCB wiring is relatively long and requires a certain drive capability. Additionally, it is not recommended to use internal pull-up resistors as external pull-up resistors have better driving capabilities.
We suggest that you set the power supply voltage of both the host MCU platform and BHI360 to 1.8V, so that you can directly connect the host MCU and BHI360 without using level conversion.
