    BNO055 problem: I2C bus is busy
    Melek_Cherif
    Hi everyone,
    For days, I have had a problem initializing the BNO055 IMU sensor with the ESP32. After troubleshooting , here is the output of i2c tool? This always causes a blockage in reading and writing to the sensor.
    Note that I am using esp-idf, and when i tried the same hardware with Arduino IDE, it worked perfectly.
    Also here is a snippet of my code:
    BNO055_RETURN_FUNCTION_TYPE BNO055_I2C_bus_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t cnt)
        int comres = 0;  // Result of communication
        i2c_cmd_handle_t cmd = i2c_cmd_link_create();
        // Start transmission
        i2c_master_start(cmd);
        // Send device address and write bit
        i2c_master_write_byte(cmd, (dev_addr << 1) | I2C_MASTER_WRITE, ACK_CHECK_EN);
        // Send the register address
        i2c_master_write_byte(cmd, reg_addr, ACK_CHECK_EN);
        // Stop transmission
        i2c_master_stop(cmd);
        esp_err_t ret = i2c_master_cmd_begin(I2C_MASTER_NUM, cmd, pdMS_TO_TICKS(1000));
        i2c_cmd_link_delete(cmd);
        if (ret != ESP_OK) {
            ESP_LOGE(TAG, "I2C Write failed");
            return -1;  // Communication failure
        // Small delay to ensure data is ready
        esp_rom_delay_us(150);
        // Create new command for reading data
        // Send device address and read bit
        i2c_master_write_byte(cmd, (dev_addr << 1) | I2C_MASTER_READ, ACK_CHECK_EN);
        // Read the data
        if (cnt > 1) {
            i2c_master_read(cmd, reg_data, cnt - 1, ACK_VAL);
        i2c_master_read_byte(cmd, reg_data + cnt - 1, NACK_VAL);
            ESP_LOGE(TAG, "I2C Read failed");
            return -1;
        return comres;
    BNO055_RETURN_FUNCTION_TYPE BNO055_I2C_bus_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t cnt)
        BNO055_RETURN_FUNCTION_TYPE comres = 0;  // Result of communication
        // Write the data
        for (uint8_t index = 0; index < cnt; index++) {
            i2c_master_write_byte(cmd, reg_data[index], ACK_CHECK_EN);
        // Small delay to ensure data is written
        return comres;
    void bno055_task(void *pvParameter) {
        struct bno055_t bno055 = {
            .bus_read = BNO055_I2C_bus_read,
            .bus_write = BNO055_I2C_bus_write,
            .dev_addr = 0x29,
            .delay_msec = _delay
        BNO055_RETURN_FUNCTION_TYPE com_rslt;
        struct bno055_accel_t accel_data;
        bool sensor_ready = false;
        // Initialize BNO055 sensor
        com_rslt = bno055_init(&bno055);
        if (com_rslt == BNO055_SUCCESS) {
            // Set operation mode
            com_rslt = bno055_set_operation_mode(BNO055_OPERATION_MODE_NDOF);
                sensor_ready = true;
            } else {
                ESP_LOGE(TAG, "BNO055 set operation mode failed with code: %d", com_rslt);
        } else {
            ESP_LOGE(TAG, "BNO055 initialization failed with code: %d", com_rslt);
        while (1) {
            if (sensor_ready) {
                // Read Euler angles with error handling
                com_rslt = bno055_read_accel_xyz(&accel_data);
                    ESP_LOGI(TAG, "Accel X: %d, Y: %d, Z: %d", accel_data.x, accel_data.y, accel_data.z);
                else
                    ESP_LOGE(TAG, "BNO055 read accel failed with code: %d", com_rslt);
            vTaskDelay(100); // Adjust delay as needed
    And this is the output:
    Any help or comment would be appreciated.
    0 REPLIES 0
