    BSEC 2.5.0.2 Example Code Bug in bsecInstance Allocation
    WilliamElder
    Occasional Visitor
    Hello. Apologies for using this forum for bug reports, but I couldn't seem to find a relevant GitHub page for the non-Arduino BSEC's issues. The version of BSEC 2.5.0.2 I downloaded on 6/19/2024 is from https://www.bosch-sensortec.com/software-tools/software/bme680-software-bsec/.
    I used the reference code in BSEC 2.5.0.2's bsec_integration.c/.h files and started having memory write access errors when calling bsec_iot_init(). I found that bsecInstance's pointers weren't being set in bsec_iot_example.c/.h or bsec_integration.c/.h's code, and since neither allocateMemory() nor bsec_mem_block were being used, I fixed the bug and a few other compiler warnings by changing:
    in bsec_integration.h:
    uint8_t					bsec_mem_block[NUM_OF_SENS][BSEC_INSTANCE_SIZE];
    uint8_t *bsecInstance[NUM_OF_SENS];
    to:
    extern uint8_t bsecInstance[NUM_OF_SENS][BSEC_INSTANCE_SIZE];
    and in bsec_integration.c, I:
    added #import <string.h> to fix a missing import with memset() under the "header files" section,
    removed the allocateMemory() function since it was unused,
    and added:
    to the "global variable declarations" section.
    My project compiles and runs fine after making the changes.
    Will
    Hi WilliamElder,
    Thank you for your feedback. Yes, currently only the BSEC software package contains non-Arduino BSEC code. You can refer to the example code and make modifications in the code.
