    BSEC library for Azure Sphere
    jeremynz
    I posted some of this earlier at the end of this thread https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BSEC-integration-problem-on-gcc-Cortex-A... but perhaps it was unnoticed as that thread is already marked as solved.
    I'm using a BME680 with an Azure Sphere kit. I want to use the BSEC library but I am getting a variety of linking errors.
    The Azure Sphere is based off a MT3260, which has a Cortex-A7 core and 2 x Cortex-M4 cores. I want to integrate the BSEC library into my Cortex-A7 application.
    I have tried the following versions of libalgosec.a:
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.4_Generic_Release.zip
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_interface.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_interface.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_interface.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_get_version.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_init.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_init.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_reset_output.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_configuration.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_set_state.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(constructor_bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(constructor_bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(constructor_bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Bsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Bsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Bsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ChannelHub.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ChannelHub.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ChannelHub.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Entity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Entity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Entity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(HumidityTemperatureCorrector.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(IaqEstimator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(IaqEstimator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(IaqEstimator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(SensorStatusTracker.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(SensorStatusTracker.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Serialization.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Serialization.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Serialization.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_data.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_data.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(bsec_codegen_rtwutil.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(convertHumidity.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(convertHumidity.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(convertHumidity.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(crcCcitt2.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(crcCcitt2.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(crcCcitt2.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(isequal.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(isequal.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(isequal.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(log10.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(log10.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(log10.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(polyval.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(polyval.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(polyval.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sqrt.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sqrt.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sqrt.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(Channel.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(Channel.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(Channel.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothing.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothing.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothing.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(ExpSmoothingBsec.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(applyScalarFunctionInPlace.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: error: bin\ARM\Debug\HighLevelApp.out uses VFP register arguments, libraries\BSEC\libalgobsec.a(sin.o) does not
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(sin.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: failed to merge target specific data of file libraries\BSEC\libalgobsec.a(sin.o)
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_sensor_control.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv2' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_THM_MOVW_ABS_NC against `iv1' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_THM_MOVW_ABS_NC against `uv0' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o)(.text+0x54864700000376): unresolvable (null) relocation against symbol `R_ARM_THM_CALL'
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: final link failed: nonrepresentable section on output
    collect2.exe : error : ld returned 1 exit status​
    • algo\normal_version\bin\gcc\Cortex_A7\libalgosec.a from BSEC_1.4.7.2_GCC_CortexA7_20190225.zip
    • COINES\sensorAPI\bme680\BSEC\algo\bin\linux_armhf\libalgosec.a from COINES_v2.0_Linux.sh:
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_interface.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_do_steps.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(bsec_codegen_update_subscription.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(Bsec.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityBaselineTracker.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(GasHumidityPreProcessor.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(SensorHeatCompensator.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(crcCcitt2.o): relocation R_ARM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: libraries\BSEC\libalgobsec.a(ChannelHub.o)(.text+0x5486470000086c): unresolvable (null) relocation against symbol `R_ARM_CALL'
    Can someone from Bosch help to provide a precompiled library to resolve these errors? The standard gcc options for the Azure Sphere toolchain are:
    -c -x c -I DRIVERS/BME680 -I LIBRARIES -I DRIVERS -I "C:\PROGRAM FILES (X86)\MICROSOFT AZURE SPHERE SDK\SYSROOTS\3+BETA1909\USR\INCLUDE" -I ..\HARDWARE\AVNET_MT3620_SK\INC -g2 -gdwarf-2 -Wall -W"strict-prototypes" -Wswitch -W"no-deprecated-declarations" -W"empty-body" -Wconversion -W"return-type" -Wparentheses -W"no-pointer-sign" -W"no-format" -Wuninitialized -W"unreachable-code" -W"unused-function" -W"unused-value" -W"unused-variable" -W"deprecated-declarations" -O0 -fno-strict-aliasing -fno-omit-frame-pointer -D_POSIX_C_SOURCE -fno-exceptions -std=c11 -fstack-protector-strong -Werror=implicit-function-declaration -B "C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909\tools\gcc" -march=armv7ve -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 -ggdb -fPIC -ffunction-sections -fdata-sections --sysroot="C:\Program Files (x86)\Microsoft Azure Sphere SDK\Sysroots\3+Beta1909"
    I believe using the -fPIC -mfloat-abi=hard -fno-short-enums options when compiling BSEC will help resolve my errors.
    16 REPLIES 16
    handytech
    Could you please try the attached release compiled with the requested flasgs (-fPIC -mfloat-abi=hard -fno-short-enums)?
    I have tried to link against the library you provided. I can confirm the linker errors are resolved, but there are still the following warnings:
    /Program Files (x86)/Microsoft Azure Sphere SDK/Sysroots/3+Beta1909/tools/gcc/real-ld.exe: warning: libraries\BSEC\libalgobsec.a(rdivide_helper.o) uses variable-size enums yet the output is to use 32-bit enums; use of enum values across objects may fail
    I will continue testing to see if I can get meaningful numbers out of the BSEC library, but this will take me another day or two.
    I'm sorry to report I have been unable to have any success with the library you attached.
    There are no more linker errors (there are warnings as previously mentioned), so the build completes successfully. However when I try to run the application, I get an error.
    This error is only occurring if I am calling to the BSEC library eg. bsec_init(). If I don't call any BSEC functions, then everything is okay.
    I have lodged a question on the Azure Sphere forum to see if this is a known issue. https://social.msdn.microsoft.com/Forums/en-US/2a8354d5-9a7c-4046-9431-f10c4fbf4605/error-when-calli...
    After some discussion, I think the problem may be because the library provided was compiled with gcc-arm-none-eabi ( float unknow ) thumb.
    The Azure Sphere is Linux-based, so I need a library compiled with gcc-arm-linux-eabi-hf.
    Are you able to provide that please?
    The approach that should be guaranteed to work would be to compile the library with the Azure Sphere toolchain addon for Visual Studio https://aka.ms/AzureSphereSDKDownload
    If it's quicker for you to provide a variant of the BSEC library found in COINES (but with -fPIC and hard float) I am happy to try that, but it might have other issues.
    Hi, I'm not trying to nag, but I would just like to know what the chances of getting a compatible library are.
    The project I am working on is a proof of concept with a hard deadline in a couple of weeks. I'm wanting to get a measure of air quality, and also better-compensated values for temperature and humidity, so was hoping to use the BSEC library with my BME680 on the Azure Sphere board.
    The best possible result for me would be a BSEC library compiled in Visual Studio using the Azure Sphere toolchain as that would certainly be compatible.
    Alternatively your normal Linux library compiled with the options that are required to link to Azure Sphere (see my post at https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BSEC-library-for-Azure-Sphere/td-p/9840) might work.
    If it's not going to happen I will need to figure out alternative methods or sensors to get the information for my project, so would like to know as soon as possible.
    Thanks, Jeremy
